XenForo 2.1.1 & Add-ons Released plus XenForo Importers 1.2.0
XenForo 2.1.1 is now available for all licensed customers to download. We recommend that all customers running previous versions of XenForo 2.1 upgrade to this release to benefit from increased stability.
We have also made some improvements to the importer framework. Notably it is now possible to perform a multi-process import in order to make better use of multi-core processors. If you run an import via the CLI and you add the --processes option with a value greater than 1, then multiple PHP processes will be used to perform the import, instead of a single CPU core being used as is the PHP default. Your results may vary, but with the number of processes set to equal the number of physical cores on a sufficiently powerful server, you should notice a significant increase in performance.
You can also run your import command with the new --finalize option which will run the finalize stage automatically after the data import has finished.
While we're talking about importers we should also point out that we are today also releasing XenForo Importers 1.2.0 with a new "Invision Community Forums" importer, XenForo Media Gallery 2.1.1 which reintroduces a number of importers originally included in XFMG 1.x and XenForo Resource Manager 2.1.1 which includes an XFRM to XFRM importer. See below for more information.
If you are upgrading from XenForo 2.1.0, please be aware that there is a new option called "Convert Markdown-style content to BB code" which is now disabled by default. If you would like to use Markdown-style formatting in your messages, you will need to enable this option first.
Download XenForo 2.1.1
Other changes in XF 2.1.1 include:
The following public templates have had changes:
  • app_nav.less
  • app_sectionlinks.less
  • app_staffbar.less
  • bb_code.less
  • bb_code_preview.less
  • bookmark_edit
  • bookmark_macros
  • category_view
  • core_bbcode.less
  • core_block.less
  • core_contentrow.less
  • core_menu.less
  • core_pikaday.less
  • core_tab.less
  • editor.less
  • forum_post_thread
  • forum_view
  • google_analytics
  • member_macros
  • member_tooltip
  • member_view
  • PAGE_CONTAINER
  • poll_macros
  • prefix_input
  • register_form
  • register_macros
  • share_page_macros
  • structured_list.less
  • thread_list_macros
Where necessary, the merge system within the "outdated templates" page should be used to integrate these changes.
As always, new releases of XenForo are free to download for all customers with active licenses, who may now grab the new version from the customer area.
Note: add-ons, customizations and styles made for XenForo 1.x are not compatible with XenForo 2.x. If your site relies upon these for essential functionality, ensure that a XenForo 2 version exists before you start to upgrade. We strongly recommend you make a backup before attempting an upgrade.
Current Requirements
Please note that XenForo 2.1.x has higher system requirements than XenForo 1.x.
The following are minimum requirements:
  • PHP 5.6 or newer (PHP 7.3 recommended)
  • MySQL 5.5 and newer (Also compatible with MariaDB/Percona etc.)
  • All of the official add-ons require XenForo 2.1.
  • Enhanced Search requires at least Elasticsearch 2.0.
Installation and Upgrade Instructions for XenForo 2.1
Full details of how to install and upgrade XenForo can be found in the XenForo 2 Manual.
Note that when upgrading from XenForo 1.x, all add-ons will be disabled and style customizations will not be maintained. New versions of add-ons will need to be installed and customizations will need to be redone. We strongly recommended that you make a backup before attempting an upgrade. Once upgraded, you will not be able to downgrade without restoring from a backup.
Download XenForo 2.1.1 & Add-ons Released plus XenForo Importers 1.2.0:
Code:
Google Drive: https://drive.google.com/drive/folders/1Wiba0quH6F3Q-cIZ_LHBUJCyrmvR94CP?usp=sharing
XenForo 2.1.1 FULL - Zippyshare: https://www39.zippyshare.com/v/o8LWvOIT/file.html
XenForo 2.1.1 UPGRADE - Zippyshare: https://www39.zippyshare.com/v/gNaFre5j/file.html
Pass: vietfriend.org
XenForo Media Gallery 2.1.1 Released
XenForo Media Gallery 2.1.1 is now available for all licensed customers to download. We recommend that all customers running previous versions of XenForo Media Gallery 2.1 upgrade to this release to benefit from increased stability.
Download XenForo Media Gallery 2.1.1
In addition to the usual bug fixes and improvements, we have also added support for importing from the following galleries:
  • XenForo Media Gallery 2.0
  • XenForo Media Gallery 2.1
  • vBulletin Albums 3.x
  • vBulletin Albums 4.x
  • Invision Community Gallery 4.x
  • Photopost Pro 8.x
  • Photopost vBGallery
Some of the other changes in XFMG 2.1.1 include:
  • approval_item_xfmg_media
  • core_xfmg.less
  • xfmg_item_list.less
XenForo Media Gallery 2.1.1 requires XenForo 2.1.1 or later.
All customers with active licenses may now download the new version from the customer area.
Purchasing
XenForo Media Gallery can be purchased with a new license via the purchase page or with an existing license via the customer area.
Installation, Upgrading and Configuration
Please see our XenForo Media Gallery manual page for more information.
Download XenForo Media Gallery 2.1.1:
Code:
XenForo Enhanced Search 2.1.1 Released
XenForo Enhanced Search 2.1.1 is now available for all licensed customers to download. We recommend that all customers running previous versions of XenForo Enhanced Search 2.1 upgrade to this release to benefit from increased stability.
Download XenForo Enhanced Search 2.1.1
Some of the changes in XFES 2.1.1 include:
XenForo Enhanced Search requires XenForo 2.1 or later.
Purchasing
XenForo Enhanced Search can be purchased with a new license via the purchase page or with an existing license via the customer area.
Please see our XenForo Enhanced Search manual page for more information.
Download XenForo Enhanced Search 2.1.1:
Code:
XenForo Resource Manager 2.1.1 Released
XenForo Resource Manager 2.1.1 is now available for all licensed customers to download. We recommend that all customers running previous versions of XenForo Resource Manager 2.1 upgrade to this release to benefit from increased stability.
Download XenForo Resource Manager 2.1.1
Some of the changes in XFRM 2.1.1 include:
  • xfrm_resource_view
XenForo Resource Manager 2.1.1 requires XenForo 2.1.1 or later.
Purchasing
XenForo Resource Manager can be purchased with a new license via the purchase page or with an existing license via the customer area.
Please see our XenForo Resource Manager manual page for more information.
Download XenForo Resource Manager 2.1.1:
Code:
XenForo Importers 1.2.0 Released
XenForo Importers 1.2.0 is now available for all licensed customers to download. If you have already successfully completed your import, you will not need to upgrade.
Download XenForo Importers 1.2.0
Some of the changes in XFI 1.2.0 include:
  • New importer to allow importing from Invision Community Forums 4.x.
  • Fixes to the XenForo 2.1 to XenForo 2.1 importer.
XenForo Importers requires XenForo 2.1 or later.
From the Licensed Customer Area
Please see our XenForo Importers manual page for more information about importing.
Download XenForo Importers 1.2.0:
Code:
Chủ đề tương tự
