Resource icon
Shoutbox by Siropu 1.3.5
No permission to download
dinhphucv submitted a new resource:
Shoutbox by Siropu - A lightweight shoutbox widget.
This is a shoutbox widget that you can add in any of the available widget positions.
Options:
  1. Minimum age required - Enable shoutbox based on user's age.
  2. Shoutbox refresh interval - Allows you to set refresh interval for new messages. This option can be disabled.
  3. Maximum shout length - Set the maximum allows shout length.
  4. Minimum time between shouts - Flood check (with user group permission to bypass it)
  5. Shout display limit - Set the maximum number of shouts...
Read more about this resource...
Chủ đề tương tự
