Content Ratings for XF2.0
Content Ratings for XF2.0 1.3.14.2
No permission to download
dinhphucv submitted a new resource:
Content Ratings for XF2.0 - Allows users to rate content more expressively
Inspired by the XF1 add-on "Post Ratings", and the prevalence of "Reactions" as an alternative to the single dimensional Likes.
Does not work with XF 2.1
To consolidate alerts use Alert Improvements
Post Installing
This add-on will require configuration
, only a default "Like" is added after installing.
Read more about this resource...
dinhphucv updated Content Ratings for XF2.0 with a new update entry:
1.3.4 - Bugfix update
  • Fix received like ratings count is displayed as 0 (affecting 1.3.x)
    • Note if you did a received rating count rebuild and had the option "Allow rebuild operations to reduce a user's rating counts" enabled (it is disabled by default) then the received Like ratings count has been set to zero. Simply run the rebuild operation again.
  • Fix like icon's not showing on rated posts (affecting 1.3.x)
  • Fix rebuilding received likes counts (affecting 1.3.x)
  • Update...
Read the rest of this update entry...
Chủ đề tương tự
